• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    CAD-One
    Accepted Solution
    Life Cycle Definition
    182 Views, 6 Replies
    10-06-2011 02:50 PM
    I noticed that I cant delete a used lifecycle definition. I opt out the part/drawing to a None lifecycle but still cant find that we cant delete a life cycle definition.
    I understand that somewhere high up in the history tab, an old version might have used that lifecycle. Is there a way to getrid of it? I dont want users to use it anymore.
    Is there a solution?
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    Please use plain text.
    Employee
    Re: Life Cycle Definition
    10-06-2011 06:48 PM in reply to: CAD-One
    You can not delete if a previous revision of a file used this Lifecycle.
    However, you can remove it from all the categories and no user will be able to apply it to future files.
    Mikel Martin
    Lead User Experience Designer
    Data Management
    Autodesk, Inc.
    CAD-One
    10-06-2011 08:36 PM in reply to: mikel.martin
    Mikel,
    1. I went to edit mode of the lifecycle definition. Right under the title I see a categories dropdown. Currebtly I had engineering selected. I unchecked that, applied, saved & exit. Is there any other place I should look?
    2. Also, now that this life cyle will not be available for use, for the files that are already in this cycle, Can I assign to opt out (None) & then change the life cycle to new one?
    C1
    Employee
    10-06-2011 08:56 PM in reply to: CAD-One
    You can change what category a LC is assigned to with the workflow you describe or you can go to the Categories dialog and change it there. Both have the same result.
    You dont have to change a file to None before switching it to another Lifecycle def.
    You can change to any Lifecycle assigned to the files category. A category may have more than one lifecycle assigned.
    You may change the Lifecycle that a file is assigned to in the Change State command.
    Hope this helps.
    Mikel Martin
    Data Management
    Autodesk, Inc.
    CAD-One
    10-06-2011 09:27 PM in reply to: mikel.martin
    Thanks a lot
    C1
    *Expert Elite*
    ScottMoyse
    10-08-2011 01:52 PM in reply to: CAD-One
    CAD-One you shoudl use the accept as solution if this has been resolved. It helps other people later on when searching the forums for solutions
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    CAD-One
    10-08-2011 03:21 PM in reply to: CAD-One
    Scott, thanks for prompting. :smileyhappy:
    C1
