• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor uma
    Accepted Solution
    Job Processor ignores DWF.create job (DWG AutoCAD)
    269 Views, 11 Replies
    01-08-2013 02:28 AM
    Any suggestions why Job Processor (VP2013SP1) executed on PC with installed AutoCAD 2013 and DWG TrueView 2013 could ignore the {DWF.create:*.dwg} job?
    The "Update Local" works just fine.
    in JobProcessor.exe.config there are 6 lines that contain "DWG". Only two of them are about DWF and there is no AutoCAD or Trueview mentioned in them:
    <jobHandler class="Autodesk.Vault.DWF.Create.dwg" handler="Connectivity.Explorer.JobHandlerDwfPublish.InventorDwfJobHandler, Connectivity.Explorer.JobHandlerDwfPublish"/>
    <queueDwfCreateJob extension=".dwg"/>
    Do I have some corrupt config file?
    Please use plain text.
    Employee
    chearhuat
    Re: Job Processor ignores DWF.create job (DWG AutoCAD)
    01-08-2013 09:34 PM in reply to: uma
    Hi uma,
    Could you help to elaborate on 'DWG job creation' is being ignored?
    Meanwhile, you might do a simple workflow check, to determine if Job Processor is indeed working.
    1. Run Job Processor in your local machine, via Start > Autodesk > Autodesk Data Management > Tools > Autodesk Job Processor.
    2. Via ACAD (as reported in you case), check in a simple dwg file, and send the dwf publishing job to job server (via Check In > Settings > Send to Job Server )
    3. Via Vault Client, check if the DWF file has indeed been created. You might have to turn on VE > Option > Show hidden file, to examine dwf/dwfx file.
    Let us know if that helps...
    Chear Huat.
    Chear Huat
    SQA Analyst
    DLS- Data Management
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    01-08-2013 11:49 PM in reply to: chearhuat
    Thats the problem - job stays in queue with pending status.
    At the same time DWF.create jobs for Inventor files are processed just fine....
    Active Contributor
    subsales
    01-08-2013 11:58 PM in reply to: uma
    Could you send us the config file, and also help to validate if job type 'autodesk.vault.dwf.create.dwg' is checked (should be, by default) in Job Processor > Administration > Job type?
    thanks.
    Chear Huat
    01-09-2013 12:17 AM in reply to: subsales
    Yes the job is checked. Please find the config file attached.
    Employee
    chearhuat
    01-09-2013 12:52 AM in reply to: uma
    Hi
    just examained your config file, it seems okay -- except a couple of commented line (see attached for the original config file) which shall not affect the running of job processor. You could try to rename your current config file and place the attached config file (default) in the same location. Let us know if you're still seeing the sam problem.
    Also, you should be able to find JobProcessor.log in the same folder of config file. Could you identify which time that you experience the said error, and attach the log file along?
    Appreciate your patience...
    Chear Huat.
    Chear Huat
    SQA Analyst
    Autodesk, Inc.
    01-09-2013 01:00 AM in reply to: chearhuat
    With your config the problem still actual.
    The job just stays in queue with "Pending" status.
    Log file contains no new lines since 6 Jan.
    Employee
    chearhuat
    01-09-2013 10:23 PM in reply to: uma
    Hi Uma,
    One more validation: could you start and run TrueView 2013?
    under the hook, Job Processor uses True View for DWF publishing job of ACAD drawign files.
    Chear Huat.
    Chear Huat
    SQA Analyst
    Autodesk, Inc.
    01-09-2013 11:16 PM in reply to: chearhuat
    Yes - DWG Trueview 2013 starts susscessfully.
    And yes - AutoCAD DWG files could be opened with it.
    Employee
    chearhuat
    01-09-2013 11:26 PM in reply to: uma
    Do you have a secondary machine that allows you to do some cross-checking.
    It could be an isolated case, and is machine specified.
    regards,
    Chear Huat.
    Chear Huat
    SQA Analyst
    Autodesk, Inc.
