• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Inventor LT and Vault Pro
    208 Views, 4 Replies
    03-07-2012 08:06 PM
    I have a cusotmer that is trying to use Inventor LT and Vault but we are having issues with setting the local workspace. Currently, the work path is going to %userprofile%/Documents/Vault/Designs but the actual workspace for Vault should be C:/Vault_local/Designs.
    I have noticed that I can not change the Inv LT work path unless I unload the EDM Vault add-in. However, after unloading the add-in, changing the work path and then reloading the EDM add-in...the work path will go right back to Documents/Designs.
    Is there anyway to set the Vault workspace for Inventor LT to match the Vault meaning Inventor LT does not use a project file?
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Inventor LT and Vault Pro
    03-08-2012 07:01 PM in reply to: stapprich
    Unfortunately the answer is NO. As mentioned in the Readme "When using Inventor LT with Vault, the user's workspace is hardcoded to %USERPROFILE%\My Documents\Vault\Designs and mapped to the root folder “$” in Vault. Workspace mapping cannot be changed. "
    Senthil Kumar
    Sr QA Analyst
    Be sure to check out the Vault Help Wiki!
    03-09-2012 06:53 AM in reply to: stapprich
    I appreciate the response. Can I share a concern?
    If we are not able to change the workspace to match the proper file structure, then how does Autodesk recommend we use an add-in with a program that is built on file structure?
    Thanks!
    Active Contributor
    02-11-2013 05:24 AM in reply to: stapprich
    Hi
    We are a multiple application company with different diciplines of cad applications with a set Vault Workgroup with a set folder structure, we recently bought 4 Inventor LT, only to find out its not compatible with our vault folder structure, why then the add in funtion, why hardcode something as simple as a vault add in.. doesnt make sense, and we would have bought 5 more seats, but is thinking twice now before commiting,
    Employee
    Senthil-Autodesk
    02-11-2013 06:46 PM in reply to: jacoj
    We understand your concern. I have forwarded this to the product management to take a look.
    Senthil Kumar
    Sr QA Analyst
