• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    cbenner
    Initial Vault Version Released, not WIP
    55 Views, 2 Replies
    01-31-2013 04:32 AM
    I'm going through some of our previously vaulted projects and bringing the lifecycles up to date, and I noticed several files where the initial version in Vault is set as Released.  I didn't know this was even possible, I thought initial versions were always Work In Progress.  Since these are Released with no revision information on them, if I want to use the Vault Revision table (and I do), I have to delete them from Vault and revault them from the CAD file.  Not a big deal, it's only one or two,... but does anyone know what might cause this, so I can watch for it in the future?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Please use plain text.
    Employee
    Re: Initial Vault Version Released, not WIP
    01-31-2013 06:11 AM in reply to: cbenner
    Hello Chris,
    There are a few ways that first version of the file can get into a released state. The first thing that comes to mind is that the lifecycle's default state is (or was) set to 'Released'. The default state can be any state you want. Is it possible that was the case?
    There are also other utilities that are used by resellers that could have created this scenario. But the default state seems more likely.
    Adam
    Adam Luttenbacher
    Sr User Experience Designer
    cbenner
    01-31-2013 06:22 AM in reply to: luttena
    Hmm,... that is highly possible, (probable).  It seems to be one group of files that were all vaulted around the same time period.  The current default is WIP, and all of my most recently vaulted files are just fine.
    Thanks for the reply!
    ChrisB
