• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Contributor
    Import a user from a linux domain
    152 Views, 11 Replies
    04-16-2012 10:21 AM
    Hello!
    I'm trying to import users from the domain, but show me the message "You must be authenticated to a domain in order to perform this operation" being that I'm already in the domain. It's important to know that the domain is in Linux, Is that  the problem?
    thanks!
    Please use plain text.
    Employee
    Re: Import a user from a linux domain
    04-16-2012 11:09 AM in reply to: helmartins
    Importing a domain user only works with Microsoft Domains and Windows Active Directory.  We have not done any testing on samba/linux implementations of Active Directory or LDAP.
    -Hywell
    Hywell Herrero
    Data Management Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    04-16-2012 12:00 PM in reply to: hherrero
    Ok
    07-30-2012 07:47 AM in reply to: helmartins
    I get the same error, however I am on a Windows network with Windows AD. Both machines are 2008 Server R2.
    Any ideas?
    Inventor 2012 Certified Professional
    Inventor Product Design Suite 2012 Professional
    Dell T3500 - Xeon 3.20GHz / 24GB Ram / ATI FirePro V5900
    Dell M6500 - Core i7 2.13GHz / 32GB Ram / Nvidia Quadro FX3800M
    Employee
    mollons
    07-30-2012 07:54 AM in reply to: aparrow
    Did you set up IIS to handle windows auth?
    There is information on how to do so in the advanced config guides here:
    http://wikihelp.autodesk.com/Vault/enu/Help/Help/0206-Autodesk206/0264Advanced_Configuration
    Scott Mollon
    Quality Assurance
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    07-30-2012 07:58 AM in reply to: mollons
    Working on it now. Using this:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15739768&linkID=9261340
    07-30-2012 08:17 AM in reply to: aparrow
    Still not working.
    Employee
    mollons
    07-30-2012 08:19 AM in reply to: aparrow
    Did you have to make changes to the IIS settings?
    Did you run an iisreset on the command prompt after making those changes?
    Scott Mollon
    Quality Assurance
    Autodesk, Inc.
    07-30-2012 08:26 AM in reply to: mollons
    I did and rebooted the machine for good measure.
    Any logs I can review or other places to look?
    Employee
    07-30-2012 08:54 AM in reply to: aparrow
    When you log into the ADMS Console... go to the Server Log and see if there is anything interesting there.  Another location to look would be the IIS logs but I am unsure what would be in there.  The ADMS server log should hopefully have more information on the error.  Also, can both machines see another machine on the domain?  A quick test would be having a network share somewhere and see if they can get to it.  I have had machines that I thought were on a domain when they were not.
    -Jim
