• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Valued Contributor
    sato2511
    I can't delete link between an item and document
    93 Views, 2 Replies
    07-17-2012 06:02 AM
    Hy!
    I can't delete the link between an item and the document.
    I attach image.
    Can anyone help me, please?
    Thank you!
    sato
    Please use plain text.
    Employee
    mollons
    Re: I can't delete link between an item and document
    07-17-2012 08:38 AM in reply to: sato2511
    You can't explicitly remove a tertiary link from the item (unless you are using Vault Pro 2013).
    Is the goal to delete the file or just remove it from the item?
    Scott Mollon
    Quality Assurance
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    Distinguished Contributor uma
    12-16-2012 02:14 AM in reply to: mollons
    We are suffering the issue: ALL idws created on members of particular iAssembly (Pack&Go shows that each drawing is definetly created using only ONEmember) are tetrially linked to ALL Items created on members of the iAssembly (no secondary links to other members). Of course those wrong tetr.links could be removed with Vault Explorer 2013 but this is not a solution as they return back on Item update. Does any of you have the same problem? Any ideas on how to solve?
