• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    Re: I HATE THE JOB PROCESSOR!
    03-05-2012 04:10 AM in reply to: cbenner
    Jeff
    Same set up here, domain users for log in and JP user account is vault username not domain, with full admin rights
    Client is using Vault 2012 Collaboration + SP1 and Inventor 2011 SP2
    From what I can observe JP cannot start up the Inventor session, Inventor.exe doesnt come up
    Starting Inventor manually works but very slow. I wonder if there is a timeout value or something.
    I might try a re-install of Inventor
    Max
    Please use plain text.
    jeff_jordan
    03-05-2012 06:29 AM in reply to: mbodnar
    Are there any previous versions of Inventor or Inventor view installed on this machine?  2010 and previous?  Try uninstalling all old versions of these and repair your installation of 2011.  Remember to restart between uninstalls and installs.  There may be some sort of registry conflict and you need to clear that out (reset it).
    Autodesk Product Design Suite 2012 (Inventor 2012 Pro SP1, Vault 2012 Pro Update 1)
    Windows 7, 64-bit
    Intel Core i7
    8GB
    Nvidia Quadro FX 3800M
    Member
    sylvain.bailly
    03-15-2012 09:18 AM in reply to: jeff_jordan
    Hello Jeff/Autodesk,
    We have the same problems for our JP. We would like to have information from Autodesk.
    The only one problem we have is the error "Unknown error during publish" all the time and we are obliged to generate manually the DWF. Not good because as Jeff said, we are Eng. IT for our company and not Eng, troubleshooter or beta tester of Autodesk!
    Best regards,
    Sylvain
    Valued Contributor
    Denzuki1
    03-28-2012 10:02 AM in reply to: sylvain.bailly
    Hello Jeff,
    I would like to state that I am in agreement with the statements made. These items need to be made a priority.
    thanks,
    jeff_jordan
    03-28-2012 10:09 AM in reply to: Denzuki1
    Just a quick update (after troubleshooting with Autodesk):
    1) It seems that if the job processor runs for a continuous amount of time without restarting, the likelyhood of these errors is greater.  Restarting the job processor(s) frequently seems to reduce the errors.
    2) It may be possible to setup a windows task schedular to handle restarting the job processor automatically.  Autodesk is working on more documentation regarding this.
    Until Autodesk releases the information, hopefully this will help some of you limp along for a bit.  I think this is a bandaid fix to a much larger problem, but for now we can at least get some work done.  At this point, it seems as if Autodesk is only addressing the errors and not the lack of performance.
    Thank you to those of you who have also posted your concerns.
    Windows 7, 64-bit
    Intel Core i7
    8GB
    Member
    sylvain.bailly
    03-29-2012 01:52 AM in reply to: mbodnar
    Helle Jeff,
    Thank you for this explanation but I restart the job processor every day (2 times minimum per day). Sometimes it can be done 10 times.
    Very annoying to do it even if it takes few minutes.
    Sylvain
    jeff_jordan
    03-29-2012 06:29 AM in reply to: sylvain.bailly
    Just to be clear, I'm talking about a full shutdown of the job processor...not a pause and restart.  The close button on the processor window won't shut down the processor, only File>Exit.  Why are you restarting the JP 10 times/day?  Either way, I agree...having to restart the JP is annoying.
    Windows 7, 64-bit
    Intel Core i7
    8GB
    Member
    sylvain.bailly
    03-29-2012 10:14 AM in reply to: mbodnar
    I speak about a full shutdown of the computer (virtual machine). Today I did it 3 times for example.
    When I see that the JP is blocked on a task, I am obliged to do a remote desktop on the VM, stop the process, restart the computer. Few minutes later, I am obliged to reconnect on it (log in), and at this time, when Windows is loaded, the JP is starting too automatically.
    Sylvain
    jeff_jordan
    03-29-2012 10:21 AM in reply to: sylvain.bailly
    Wow!  That's annoying.  I wonder if it may be something else, a stability issue with the vm.
    I also had problems with a dedicated JP (physical computer on the network).  It seemed to work great in the beginning but eventually the performance degraded enough that the JP was barely working.
    Windows 7, 64-bit
    Intel Core i7
    8GB
    *Expert Elite*
    cbenner
    03-29-2012 10:51 AM in reply to: jeff_jordan
    I've come to the conclusion that all of my problems with JP are processor oriented, and could be solved very easily by Vaule and JP supporting multi threading.  As far as I know, this was passed up to the development team through a service ticked logged for me, based on posts here.  So it should be taken care of real soon,.... or about the time I retire.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
