• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Contributor
    Lalitkmr123
    Help : Error 29001 during Vault 2013 upgrade
    135 Views, 2 Replies
    02-12-2013 09:39 AM
    Hi
    I got an error in vault 2013 upgrade from 2012.
    our System Configuration is :
    OS: Windows server 2008R2 SP1 (x64)
    SQL Server: SQL server 2008R2 SP1 (x86)
    it is a dedicated server for Autodesk vault.
    We had Vault 2012 installed on the server.
    As per the ducumetation I started the 2013 installation without uninstalling 2012 version.
    7 out of 8 steps in installtion went ok.
    The Error I got was Error 29001.
    I am attaching the screen capture of the error and the setup log file also.
    Any help is greatly appreciated.
    Regards
    Lalit
    Please use plain text.
    DarrenP
    Re: Help : Error 29001 during Vault 2013 upgrade
    02-12-2013 10:37 AM in reply to: Lalitkmr123
    Active Contributor
    Lalitkmr123
    02-13-2013 04:16 AM in reply to: DarrenP
    DarrenP
    Thanks for your reply. The issue was fixed . It had something to do with ASP version in IIS. Reinstalled IIS in server manager roles  as shown in advanced configuration guide and it went OK.
    Thanks again.
    Regards
    Lalit
