Autodesk Vault
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Get/Checko ut shrinkwrap parts returning Error 0: Operation failed: System error.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have some files in our Vault giving me headache..
As far as I can tell they all are all shrinkwrap/shrinkwrap substitute parts.
They have successfully been created and checked in and most of them updated more than once. "Suddenly" we get the following error when trying get/checkout from the Vault.
"Error 0 - Operation failed: System error. Please contact your system administrator."
If we try to open an assy where one of the failing shrinkwraps are used we get a different error:
"Vault - The server returned the following information: Unknown Server Error."
And the failing parts are unresolved in the assy.
I think we have all updates and service packs installed both for Inventor 2012 and Vault 2012 (basic/free/included version)
Any hints or tips?!
Thanks in advance.
Ivar Mo
Fimtech AS
Norway
Re: Get/Checko ut shrinkwrap parts returning Error 0: Operation failed: System er
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The funny thing is that I can successfully checkout an older version and update that one, but once checked in - same error...
Anyone know if this is part related or Vault related?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there anyway you can share the Dataset with me? You can send them to me at senthilDOTkumarATautodeskDOTcom
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
One of my shrinkwraps are in the mail.... 37MB... Do you accept that big attachments in your mail system?!
This file is made from a STEP or IGES import - probably imported into IV2008.
The file has an insane detail level, but the "Fill all holes" option was not present back then.... :-)
Thanks for looking into this! :-)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did we get this resolved?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, it was simply a iisrestart issue...
My backupscript did that but not in correct order.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have the same issue. Have I understand it right, did backup solve this issue in your case?
Stan Cernak
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi!
Yes and no.. The problem was both caused by the backup script I had at the time, and the issue was solved by changing the script sligthly...
Try running this on a Command Prompt window on your server:
iisreset /stop
iisreset /start
If this works, try to add the same lines at the bottom of your backupscript.
Hope you solve your problem!
/Ivar Mo
Norway
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you. It has helped, problem is solved now.
Stan Cernak
