• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Active Contributor
    Accepted Solution
    Get/Checkout shrinkwrap parts returning Error 0: Operation failed: System error.
    411 Views, 8 Replies
    02-29-2012 05:28 AM
    I have some files in our Vault giving me headache..
    As far as I can tell they all are all shrinkwrap/shrinkwrap substitute parts.
    They have successfully been created and checked in and most of them updated more than once. "Suddenly" we get the following error when trying get/checkout from the Vault.
    "Error 0 - Operation failed: System error. Please contact your system administrator."
    If we try to open an assy where one of the failing shrinkwraps are used we get a different error:
    "Vault - The server returned the following information: Unknown Server Error."
    And the failing parts are unresolved in the assy.
    I think we have all updates and service packs installed both for Inventor 2012 and Vault 2012 (basic/free/included version)
    Any hints or tips?!
    Thanks in advance.
    Ivar Mo
    Fimtech AS
    Norway
    Please use plain text.
    Active Contributor
    Re: Get/Checkout shrinkwrap parts returning Error 0: Operation failed: System er
    02-29-2012 10:35 AM in reply to: ivar.mo
    The funny thing is that I can successfully checkout an older version and update that one, but once checked in - same error...
    Anyone know if this is part related or Vault related?
    Employee
    Senthil-Autodesk
    02-29-2012 06:35 PM in reply to: ivar.mo
    Is there anyway you can share the Dataset with me? You can send them to me at senthilDOTkumarATautodeskDOTcom
    Thanks!
    Senthil Kumar
    Sr QA Analyst
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    Active Contributor
    03-01-2012 01:08 AM in reply to: Senthil-Autodesk
    One of my shrinkwraps are in the mail.... 37MB... Do you accept that big attachments in your mail system?!
    This file is made from a STEP or IGES import - probably imported into IV2008.
    The file has an insane detail level, but the "Fill all holes" option was not present back then.... :-)
    Thanks for looking into this! :-)
    07-17-2012 05:10 PM in reply to: ivar.mo
    Did we get this resolved?
    Active Contributor
    08-16-2012 02:12 AM in reply to: PACDrafting
    Yes, it was simply a iisrestart issue...
    My backupscript did that but not in correct order.
    stancernak
    08-31-2012 03:42 AM in reply to: ivar.mo
    I have the same issue. Have I understand it right, did backup solve this issue in your case?
    Stan Cernak
    Active Contributor
    08-31-2012 03:59 AM in reply to: ivar.mo
    Hi!
    Yes and no.. The problem was both caused by the backup script I had at the time, and the issue was solved by changing the script sligthly...
    Try running this on a Command Prompt window on your server:
    iisreset /stop
    iisreset /start
    If this works, try to add the same lines at the bottom of your backupscript.
    Hope you solve your problem!
    /Ivar Mo
    Norway
    stancernak
    08-31-2012 04:08 AM in reply to: ivar.mo
    Thank you. It has helped, problem is solved now.
    Stan Cernak
