• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Member
    Failing ASP Pre-check
    144 Views, 1 Replies
    10-13-2012 04:02 PM
    I'm very new to Inventor. I've loaded inventor amd it's been running for a couple of weeks OK.
    I've started to try to install Vault and Content library but it continues to fail the pre-check test ASP Status.
    The fault is "Accessing an htpp static file failed ......etc"
    If I open a browser and type in the address that fails I get "Object not Found" Errorr 404
    I'm running Norton 360, turned off the firewall and retried the browser address above but get the same result.
    If I open the "Autodesk Vault Installation Help", I don't find it helpful at all. The help section that the "Accessing an http..." error points to only restates the error message.
    Please can someone help me with what I have to do to solve this.
    I'm using Windows 7 64bit
    Cheers
    Please use plain text.
    Member
    Re: Failing ASP Pre-check
    10-13-2012 04:42 PM in reply to: adrian
    I tried all sorts of things as suggested in the help over about 3 hours. I lost count on the number of times I had to reboot.
    What fixed it was posting a message on this forum. No I didn't get an answer to my problem, the software suddenly decided to work as if by magic.
    All working OK !!
