• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Contributor amd
    amd
    Error while installing vault server 2013
    270 Views, 2 Replies
    04-19-2012 01:02 AM
    Hello all,
    i am trying to install vault server 2013 in my server. after confiuring the license details it stops proceeding with the Insatallation and give an error the .
    The Installation cannot continue. the install source fiules are located on a path  which is no longer than 76 character.
    (Attached is the screenshot of the error)
    i tried changing the Installation path still dosent work. i have never seem this error since installing 2012 couple of time in my pc.
    If anyone  has encountered this issue before Kindly let me how to fix this as cannot proceed with Installation
    thanks in advance
    Regards
    Asif
    Please use plain text.
    Active Contributor jbj
    Active Contributor
    Re: Error while installing vault server 2013
    04-19-2012 04:40 AM in reply to: amd
    You have probably placed the installation files on \\SomeServer\With\Long\PathName.
    Move it to a shorter path (eg. C:\VaultInst\ ) and try again.
    Contributor amd
    amd
    04-20-2012 02:47 AM in reply to: amd
    Thnks for the Info i managed to get over it !
    While proceeding with then Insatallation i have had this Issue whcih i cannot get through ,( Scrrenshot attached )
    any update is highly appreciated !!
    Thanks in advance !!
    best regards
