Error while installing SP1 on ADMS Pro Server
cmcconnell
cmcconnell
See screenshots - it claims iis is not running as default website. It scuttles the install. Not sure what is going on or how to fix it.
Mechanix Design Solutions inc.
DarrenP
read this: http://crackingthevault.typepad.com/crackingthevault/2012/12/vault-server-sp1-installation-error.htm...
DarrenP
cmcconnell
Strange. I can start the console without error, and my service is running. I restarted it just to make sure. Still errors out.
I will try a re-boot just for fun....
r.smith1
Hi Cory,
If I recall, you had two or more websites running on your ADMS server from one of our earlier cases.  We disabled one of them.  You may consider just removing IIS then running a reinstall of ADMS to rebuild the websites then retry the install of SP1.  This may also clear up your other issue that you were having.
Ron Smith
New Product Introduction Manager
Autodesk, Inc.
cmcconnell
This is on a completely different server - one I set up about a month ago.
r.smith1
Resolution to this issue can now be found on our Support Blog:
http://crackingthevault.typepad.com/crackingthevault/2012/12/iis-is-not-running-as-the-default-web-s...
Ron Smith
Autodesk, Inc.
