• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Employee
    KooCheeKit
    Re: Error 1455
    11-15-2012 07:23 PM in reply to: ScottMoyse
    Scott,
    Was the CER send out when Inventor crashes?
    Chee-Kit
    Data Management
    Please use plain text.
    ScottMoyse
    Re: Error 1455
    11-15-2012 07:27 PM in reply to: KooCheeKit
    Historically yes lots of them have been sent out. Dozens and dozens, since we have had inventor crash with idw check in lots of times this year.
    We think the one today was sent out, if not they have been on previous days. The computer name is Design_31
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Distinguished Contributor uma
    Re: Error 1455
    11-19-2012 11:37 AM in reply to: ScottMoyse
    I wonder .. does anyone of users that suffer the 1455 issue is working in replicated environment?
    csmac2004
    Re: Error 1455
    12-17-2012 03:47 PM in reply to: uma
    Getting this error here as well, so this thread has been some great reading material for the past 20 minutes... Haha!
    We, too, have been getting a lot of Inventor crashes when checking in files. On that note, I did notice in the Vault update 1 Readme that many crashing Inventor issues have been fixed. We will try and get the update on as soon as possible and see if that maybe relieves the issue, but I was wondering if someone here can comment who has tried the update already?
    Scott MacDonald
    Inventor 2013 Product Design Suite
    Vault Professional 2013
    Windows7 x64
    Autodesk Inventor Certified Professional
    mthomas
    Re: Error 1455
    12-18-2012 06:40 AM in reply to: csmac2004
    We put the Vault SP in last week Thursday and the Inventor update on Friday, so far no new error 1455's but we've really only been at it for a day
    Mike Thomas
    csmac2004
    Re: Error 1455
    12-18-2012 07:17 AM in reply to: mthomas
    I'll talk with IT about the Vault SP today. You always were a keener, Mike... :smileywink:
    Scott MacDonald
    Windows7 x64
    mthomas
    Re: Error 1455
    02-26-2013 08:14 AM in reply to: csmac2004
    Its baaaccckkkk and with a vengence, we are seeing a lot of files / items the past 48-hours displaying this same issue.
    It seems to have started again since applying Update 2 for Inventor 2013. I'm going to try removing the update from my system and hopefully it makes the difference
    Mike:smileymad:
    Mike Thomas
    ScottMoyse
    Re: Error 1455
    02-26-2013 11:32 AM in reply to: mthomas
    keep us posted I was just about to install this
    Cheers
    Scott Moyse
    Re: Error 1455
    02-26-2013 04:29 PM in reply to: mthomas
    Are all associated files with any of the items your working with checked out?
    If yes, try checking in all files and see if this fixes the error 1455.
    If not, are any of the items in work in progress that have been previously released by a controlled change oder?
    If yes and you are recieving the error, this seems to be an issue for Autodesk to inspect.
    mthomas
    Re: Error 1455
    02-27-2013 05:54 AM in reply to: PACDrafting
    It is looking like it is not related to Update 2 for Inventor, just a really big coincidence that the issue has reappeared
    I took 3-assemblies yesterday, 2 that I was trying to assign items for the first time and one that is already assigned to an item but is in WIP and part of an open change order
    For the first two I checked out all, rebuilt within Inventor and checked-in deleting the local copies and was able to assign items. I did check prior and nothing was checked out.
    The 3rd assembly in question is attached to a change order, but this is the first change order that it is involved in and the change order has been created to release the item for the first time. We're stuck in the work phase as we can't update the item to change it to In Review. I tried the trick of check-out all, rebuilt, check-in deleting local copies with no luck. I also checked and none of the files were checked out prior to me working with it.
    I did have a conversation with Autodesk Tech Support yesterday but there was no resolution
    Mike Thomas
