• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Employee
    KooCheeKit
    Re: Error 1455 Follow up
    11-08-2012 07:19 PM in reply to: ScottMoyse
    Please log this issue with product support. Have to look into the database to determine the cause of the issue.
    If you could share your backup at the state where the issue can be repro, i will take a look into the issue. After the backup, remove the filestores from the backup, this will reduce the size of the backup.
    Chee-Kit
    Data Management
    Autodesk, Inc.
    Please use plain text.
    Distinguished Contributor
    11-09-2012 01:54 AM in reply to: KooCheeKit
    Hi
    We also have the same problem
    It is logged as Case 07623711
    Please prioritize this as there are several customer reporting it and there are no workaround as I can see
    The Item can not be updated, export to ERP stop..., etc
    br
    Svein
    Distinguished Contributor uma
    11-09-2012 02:54 AM in reply to: SveinE
    Just in case, you can try this workflow:
    1. Remove all file links
    2. Assign primary file back
    3. Update Item
    *Expert Elite*
    ScottMoyse
    11-09-2012 02:55 AM in reply to: uma
    cheers for the suggestion, but often you can't create the item in the first place let alone update it...
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    11-09-2012 02:59 AM in reply to: ScottMoyse
    Not sure I understand you clearly.
    Are you sure everything that need to be checked-in prior to Item creation is checked-in?
    *Expert Elite*
    ScottMoyse
    11-09-2012 03:07 AM in reply to: uma
    yes everything is checked in. This is a known issue. one which has been around for months now but unfortunately still hasn't been fixed. It only appears to occur on installations where Vault 2013 ADMS is installed & being used with Inventor 2012 & Vault Client/AddIn 2012
    Cheers
    Scott Moyse
    *Expert Elite*
    ScottMoyse
    11-09-2012 03:12 AM in reply to: KooCheeKit
    Chee-Kit
    thankyou I have logged it and supplied a link to download our database. The support case number is:
    07798022
    Cheers
    Scott Moyse
    11-09-2012 03:12 AM in reply to: ScottMoyse
    ADMS 2013, Inventor 2013 sp1.1 and Vault Pro 2013 client on this site
    br
    Svein
    *Expert Elite*
    ScottMoyse
    11-09-2012 03:14 AM in reply to: SveinE
    br
    Svein
    well that makes it even worse. I had hoped that upgrading to Inventor 2013 in a couple of weeks would alleviate the problem.
    Did you submit a backup of your database as well Svein?
    Cheers
    Scott Moyse
    11-09-2012 03:15 AM in reply to: ScottMoyse
    Sorry:-(
    br
    Svein
