Autodesk Vault
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Error 1455 Follow up
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please log this issue with product support. Have to look into the database to determine the cause of the issue.
If you could share your backup at the state where the issue can be repro, i will take a look into the issue. After the backup, remove the filestores from the backup, this will reduce the size of the backup.
Chee-Kit
Data Management
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
We also have the same problem
It is logged as Case 07623711
Please prioritize this as there are several customer reporting it and there are no workaround as I can see
The Item can not be updated, export to ERP stop..., etc
br
Svein
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just in case, you can try this workflow:
1. Remove all file links
2. Assign primary file back
3. Update Item
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not sure I understand you clearly.
Are you sure everything that need to be checked-in prior to Item creation is checked-in?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
yes everything is checked in. This is a known issue. one which has been around for months now but unfortunately still hasn't been fixed. It only appears to occur on installations where Vault 2013 ADMS is installed & being used with Inventor 2012 & Vault Client/AddIn 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ADMS 2013, Inventor 2013 sp1.1 and Vault Pro 2013 client on this site
br
Svein
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
SveinE wrote:ADMS 2013, Inventor 2013 sp1.1 and Vault Pro 2013 client on this site
br
Svein
well that makes it even worse. I had hoped that upgrading to Inventor 2013 in a couple of weeks would alleviate the problem.
Did you submit a backup of your database as well Svein?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry:-(
br
Svein
