• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    JamieVJohnson2
    Re: Default AutoCAD Profile when opening file from Vault 2012
    08-19-2011 08:15 AM in reply to: Dull_Blades
    On a related note, I found for certain that if you delete all profiles, the Vault Explorer is attempting to access the <<Vanilla>> profile, so it recreates it on purpose.
    One 'crazy' solution would be to replace the <<Vanilla>> profile with a copy of the company standard profile in the UserCacheData folder, but then if you need root vanilla back, you would have to get it from disc, or some other cleaver backup means.  In addition you would want to do the same to the default mechanical profile, that was all 3 profiles are the same.
    So simply put, where does the Vault Explorer store the list of profiles it is trying to use.  Allow to Modify that list, and were done here.
    jvj
    jvj
    Please use plain text.
