• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Distinguished Contributor
    Custom Inventor iProperty Group & Vault
    178 Views, 7 Replies
    11-06-2007 10:04 AM
    I created a custom iProperty group in an Inventor file via the API and when adding this file to the Vault the new iProperties contained in this custom group are not available or visible. Is this a known missing feature or is there a trick to get it to read these iProperties?
    Please use plain text.
    *Brian Roepke \(Autodesk, Inc.\)
    Re: Custom Inventor iProperty Group & Vault
    11-07-2007 06:30 AM in reply to: Thomas.Rambach
    Can you post an example file?
    Thank You,
    Brian Roepke
    Manager, Customer Success, Data Management
    "TRambach" wrote in message news:5770622@discussion.autodesk.com...
    11-07-2007 06:37 AM in reply to: Thomas.Rambach
    See attached Inv2008 DWG file. I added a text note showing the iProperties that I want to appear in the Vault. The code used to create the custom property set is stored within the file.
    Add this file to your vault and you'll see the properties are not available in the vault property set.
    (see you at AU Brian)
    11-07-2007 10:29 AM in reply to: Thomas.Rambach
    Hi Tom,
    I'm getting the same result as you - I can't see any of the ACAD properties.
    you might want to log this with support to see if they can assist.
    Thank You,
    Brian Roepke
    11-07-2007 10:40 AM in reply to: Thomas.Rambach
    Will do... thanks.
    *Brian Schanen \(Autodesk Inc\)
    11-08-2007 06:52 AM in reply to: Thomas.Rambach
    Tom,
    I think the issue lies in where the iProperties are stored. These properties
    are part of 'MyCustom Properties' and do not display in the regular
    structured file storage iProperties in the Inventor file. Is there any way
    you can write these to the custom iProps? These will index and appear in
    Vault. Thanks.
    Brian Schanen
    Customer Success Engineer, Data Management
    "TRambach" wrote in message news:5771500@discussion.autodesk.com...
    11-08-2007 07:03 AM in reply to: Thomas.Rambach
    We could but we were looking into the idea of forcing users to use a macro to enter iProperties to keep our standards enforced. The only way to do this is through a custom group that can not be edited thru the iProperties dialog.
    We may decide against this, but the other issue is our date format standard is "NOV 08 2007". Unfortunatly, Windows doesn't capitalize the month so the title blocks say "Nov 08 2007"
    Where can I add custom iProperty groups to the Vault wishlist?
    05-11-2012 12:17 PM in reply to: *Brian Schanen \(Autodesk Inc\)
    *Brian Schanen \(Autodesk Inc\) wrote:
    Tom,
    Vault. Thanks.
    Brian Schanen
    I have created new format and added new iprops to the custom tab in drawing but they are not showing up in Vault so i can add to my search options. I see the addins for my custom parts list columns. And i am positive i have done this in the past, but i have no idea what i am missing and done wrong.
    MSK
    IV2012
