• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Scotty87
    Copy Design Restriction
    497 Views, 5 Replies
    02-16-2012 01:29 PM
    Recently I have changed workstations, and while attempting to copy design a .iam file (I have also tried on .ipt and .idw files, as well as files that I have previously performed copy design on) I get the following message:
    "XXXX.iam cannot be copied due to vaulting restictions."
    "Copy Design is not supported on the selected file type."
    Anyone else have this problem and/or know of a fix?
    Cheers.
    Please use plain text.
    Board Manager
    Re: Copy Design Restriction
    02-23-2012 12:11 AM in reply to: Scotty87
    Thank you posting this message.
    It seems that all inventor files can't be copy design in the new workstations, is there a compatible Inventor installed in this workstation?
    Carrie
    Active Member
    03-01-2012 02:56 PM in reply to: Scotty87
    I am having the same problem and the same error message. We have nine workstations with all the same version of Vault and Inventor. Only two of the workstations have the problem.
    Any other ideas?
    Earl
    Active Member
    05-14-2012 06:18 PM in reply to: Scotty87
    Today I got the same problem... Someone have a solution? (I'm using AIP2013 with Vault basic and ADMS on the same workstation)
    Scotty87
    05-15-2012 04:40 AM in reply to: Scotty87
    Hey, after trying just about everything, I had to format my computer. Not a fun task, but it solved my problem.
    Active Member
    05-15-2012 06:09 AM in reply to: Scotty87
    well, I guess it's better to spend no more time trying. I will format my computer too, anyways I have other problem with the Mold desgin Server and it looks that the solutions is format the computer.
    Thanks Scotty87
    Best regards
