• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    New Member
    Combination of Vault Collaboration 2012 and Vault Professional 2012
    346 Views, 6 Replies
    05-18-2011 09:38 AM
    HI
    Can anybody help me on this?
    With new 2012 versions it is possible to have a Vault Instalation with a combination of Vault Collaboration, Vault Professional and Vault clients?
    And, for the integrated Vault versions of Inventor, Do they still  allow 5 Vault clients for Vault Consulting?
    Please use plain text.
    Board Manager
    Re: Combination of Vault Collaboration 2012 and Vault Professional 2012
    05-18-2011 09:55 AM in reply to: Ventas
    You cannot have a combination of different clients with one vault server.
    You need 1 license per user connecting.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    New Member
    05-18-2011 11:40 AM in reply to: Ventas
    Thanks Irving.
    So it means that if I have an account for example with 6 people in eng 3 in manufacturing, and 2 in others sections that need to consult de Vault, this account cannot have 3 Vault Professional (because of the need of ECO´s and BOM´s), 6 Vault Workgroup (because they need to participate in the file revision Control, but do not participate in ECO´s) and 2 Web clients combination?.
    If I unterstand well, it means that this account need to choose Professional with web clients. And means that if Other account have only the Inventor integrated Vaults and need to manage ECO´s  they have to upgrade all of their clients and server to Vault Professional?, is that correct.
    Sorry for all this questions, I try to serch for information about the different versions and how to implement them with different client needs. So if you have some information I´ll appreciate it. Thanks a lot!.
    Board Manager
    05-18-2011 12:23 PM in reply to: Ventas
    The Vault client can only talk with it's corresponding server.  So a professional client can only talk to professional servers.  A workgroup client can only connect to a workgroup server.  The web client is read-only and doesn't require a license.
    Irvin Hayes Jr
    Product Manager
    Autodesk, Inc.
    *Expert Elite*
    ScottMoyse
    05-20-2011 09:44 PM in reply to: ihayesjr
    This NEEDS to change. The idea of having to pay for a full seat of Vault Professional just for that user to only use functions that are available in workgroup or collaboration, is frankly DISGUSTING and blatanly taking advantage!
    The licensing should be like how the Inventor Suite > Inventor Professional combination works. When using pro features it takes a pro license, when you jump back to normal features it releases the prop license and takes a workgroup one for example.
    For the most part, all designers need to do is check in and check out! Or at best participate in change orders from time to time.
    I suspect if you changed this licensing your uptake of vault would increase dramatically and in the long term, was the larger number of clients, make more money and with the increased amount of feedback and usage a better product!
    I understand it will likely be a significant rewrite of how the database works. But charge for and design the product so the Server end is standard/workgroup/collaboration/Professional (if thats the order and names of the versions) and then you pay for the client ends seperately with the same escalating feature sets.
    Along with this and a few other feature tweaks and additions, any company would be completely insane to refuse having vault as part of their design and manufacturing software suite!
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Moderator
    MiWaNiZa
    01-17-2013 12:15 AM in reply to: ScottMoyse
    Idea added at IdeaStation.
    You can kudo it to try receive feature in next Vault editions.
    ________________________________________________
    Сообщество пользователей Autodesk
    Блог
    Читаем правила форума
    Moderator
    MiWaNiZa
    01-17-2013 06:54 AM in reply to: MiWaNiZa
    Idea Status changed to: Future Consideration!!!
    Блог
