• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    jeoffry
    Accepted Solution
    Check-in folder in Autocad - does it affect file version?
    81 Views, 2 Replies
    11-30-2011 09:37 PM
    If an R13 or Autocad 2007 drawing is checked into Vault using AutoCad 2011 and the Vault add-in, will the drawing still be okay to open in R13?  Or will it be saved to Autocad 2011 format?
    Thankyou!
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Check-in folder in Autocad - does it affect file version?
    11-30-2011 10:17 PM in reply to: jeoffry
    It should retain the format. If you have XREFs repathing of XREFs happen. But otherwise it should retain the file format.
    On a safer side keep a copy of it before doing the folder check-in.
    Senthil Kumar
    Sr QA Analyst
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    jeoffry
    12-01-2011 09:40 PM in reply to: Senthil-Autodesk
    Thanks Senthil.
    I did some tests with the help of this thread and you were right.
