• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Accepted Solution
    Change Autoloader default folder
    477 Views, 5 Replies
    01-17-2012 12:24 PM
    In Autoloader, I want to map to a folder other than "Designs". It's another folder on the same level in Vault.- how can I change this setting? Autoloader always seems to default to "Designs" . The folder I need is not listed at all.
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Change Autoloader default folder
    01-17-2012 06:43 PM in reply to: tmccar
    Does this help?
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9480434&linkID=9261340
    Senthil Kumar
    Sr QA Analyst
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    01-19-2012 10:22 AM in reply to: tmccar
    Yes, that's the answer, thanks
    New Member
    ppsi.engineering
    03-22-2012 01:53 AM in reply to: Senthil-Autodesk
    Hi Senthil, thanks for this post, it was a very useful post, along with the other one you made last year regarding changing the default mapping of Content Center Files in Autoloader (http://forums.autodesk.com/t5/Autodesk-Vault/Map-Content-Center-folder-in-Autoloader/td-p/3198942).
    I was able to successfully change the mapping of the designs folder, but cant seem to change the mapping of the Content Center Folder. Attached are screenshots showing how the Designs.ipj file mapping in Inventor is to the correct Vault CC folder, but when it gets to Autoloader, it still points to the default CC folder. Also attached are the BUU.xml & Designs.ipj files.
    Should I be doing something different?
    Inventor 2012 SP1
    Vault Colloaboration 2012
    Employee
    Senthil-Autodesk
    03-22-2012 03:20 AM in reply to: ppsi.engineering
    Few changes to be done.
    1. Your BUXOM says the Project file is "Drawing.ipj". So this is the Project that you need to change for CC folder Mapping. NOT the Designs.ipj.
    2. Do not try to map to a Folder with Name "Library" or "Libraries". Try something Like "CC Folder" and see if you can map.
    Hope the above helps.
    Senthil Kumar
    Sr QA Analyst
    Autodesk, Inc.
    New Member
    ppsi.engineering
    03-22-2012 08:37 PM in reply to: tmccar
    Thanks for the quick reply. It seems that it will only work if you create a new folder when doing the mapping in Inventor. If you try and select any other existing library folder (even if the existing library folder is empty), it will not work.
