• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Employee
    Re: Can not access vault from within Inventor
    03-27-2012 08:58 AM in reply to: ro01
    Nope. That should be fine.
    Adam Luttenbacher
    Sr User Experience Designer
    Please use plain text.
    ro01
    03-27-2012 01:59 PM in reply to: luttena
    I believe I have solved the issue. Its seems to be a registry error. Thank you for your help.
    Active Contributor
    11-05-2012 10:44 PM in reply to: luttena
    Hi There
    I have this same issue and I was wondering what were the steps that you took to correct your resgistry error?
    Tarryn
    ro01
    11-06-2012 05:23 AM in reply to: luttena
    I am sorry I don't remember the exact process, our Autodesk Vendor assisted us. I believe we deleted the Inventor and Vault directories out of the registry and let the applications rebuild the registry. I don't remember if there was another step.
    Good luck
    Active Contributor
    11-06-2012 05:50 AM in reply to: ro01
    Thank you very much for the reply.
    Tarryn
    Valued Contributor
    03-01-2013 05:55 AM in reply to: tarrynd
    I'm having the same issue.
    All addins are loaded, even the hidden EDM and I have the Vault project file active.
    Does anyone knows which registry keys must be adjusted /deleted?
    Danny van Duijn
    Doug_DuPont
    04-30-2013 04:59 AM in reply to: DannyVanDuijn
     Danny,
    I have just ran into the same problem. Did you resolve this? How did you do it?
    Thanks for some help.
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    ro01
    04-30-2013 06:09 AM in reply to: luttena
    I believe what we did was delete the Inventor folder from the HKEY_CURRENT_USER\Software\Autodesk in the registry. Then when you start Inventor it will rebuild the registry correctly so it can communicate with Vault. Unfortunately this will remove any custom settings you may have done in Inventor. Remember to backup the the Inventor directory before you delete it just incase you are deleting the wrong folder.
    Good Luck
    Doug_DuPont
    05-02-2013 04:26 AM in reply to: ro01
    I found my problem,
    In Inventor I when to the Addin's Panel, Right clicked and "Show Hidden Menbers"
    The EDM Addin needed to be restarted.
    Now Why this is a Hidden Addin I don't know? It is the only 1 that is Hidden?
    Douglas DuPont
    Inventor 2013
    GeForce GTX 580
    Windows 7 64 Bit
    Valued Contributor
    05-05-2013 02:28 AM in reply to: Doug_DuPont
    Hi Doug,
    I did not solve it. The workstation was reinstalled (including OS) to solve several (performance) problems.
    Of course this issue was resolved after the reinstall.
    Danny
