• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Autoloader error
    166 Views, 5 Replies
    09-30-2011 05:41 AM
    I'm getting the following error when running the Autoloader: "A file system error has occurred: Could not find a part of the path 'E:\Ahv\000\000......"  What could this be referring to?
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Autoloader error
    10-02-2011 12:11 AM in reply to: tmccar
    I am sorry that we need more information in order to understand / reproduce the issue.
    Please let us know,
    What is the version of Autoloader you are using?
    At what stage you are getting the following error?
    Is it Inventor or AutoCAD file?
    Do you have the missing file mentioned below? If yes, are you able to open that file using the software in which it was created?
    Is it possible for you to share the dataset?
    Without the above information it will be very difficult to understand / identify the problem. So please provide as much as information.
    Senthil Kumar
    Sr QA Analyst
    Be sure to check out the Vault Help Wiki!
    10-03-2011 12:16 AM in reply to: Senthil-Autodesk
    Vault Pro 2012.
    It happens after I have scanned a folder and I click "next". The folder it refers to does not exist.
    I did a re-index recently - could it be related to that?
    Tom
    Employee
    Senthil-Autodesk
    10-03-2011 12:24 AM in reply to: tmccar
    Thanks for your reply.
    I am not sure if Re-Index was the problem or not. Were you able to Autoload any other dataset? Do you see the same issue with other Dataset also?
    How about Check-in from Inventor or Add File from Client? Do you see any issue?
    Senthil Kumar
    Sr QA Analyst
    10-03-2011 01:57 AM in reply to: Senthil-Autodesk
    It seems to happen with any dataset. I am unable to check in from Inventor 2012 as my trial license has expired.
    Employee
    Senthil-Autodesk
    10-03-2011 02:03 AM in reply to: tmccar
    In that case you can try creating a New Vault Database in ADMS and try uploading the files and see if you are able to upload using Autoloader. if that works I afraid that something is wrong with your existing Database.
    Senthil Kumar
    Sr QA Analyst
