• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Accepted Solution
    Autodesk vault 2013 Failed to aquire a license
    723 Views, 6 Replies
    09-17-2012 12:24 AM
    I install the Vault server & client in my server. Server consol is running fine but for client it is "failed to acquire a license"
    Any help
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Autodesk vault 2013 Failed to aquire a license
    09-17-2012 01:01 AM in reply to: tanveer4m
    Check this solution
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13107015&linkID=9261340
    Senthil Kumar
    Sr QA Analyst
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
    09-17-2012 03:19 AM in reply to: Senthil-Autodesk
    I have done all the changes suggested but the problem remain same. no change
    Thanks for looking at my state
    *Expert Elite*
    cbenner
    09-17-2012 06:11 AM in reply to: tanveer4m
    Have you restarted the license server?  I have notice, for an as yet unknown reason, that our server will randomly shut down and need to be restarted.  IT is helping me track when this happens to see if we notice a pattern... so far nothing.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Distinguished Contributor
    09-17-2012 06:32 AM in reply to: tanveer4m
    What type of license server do you have?    Is it configured to be redundant?
    Employee
    minkd
    09-17-2012 08:55 AM in reply to: tanveer4m
    Can you look in the vault log (vlog) on the ADMS host for the time period when you got the error?
    Also, in the same folder as the vlog there should be a licensingLog.txt file that will have additional information.
    With the combination of the two, I might be able to tell why it isn't getting licenses.
    -Dave
    Dave Mink
    Data Management
    Autodesk, Inc.
    *Expert Elite*
    DarrenP
    09-17-2012 09:22 AM in reply to: minkd
    did you create a license file for Vault Pro 2013?
