• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    New Member
    Autodesk Vault Workgroup 2012 on SBS 2011 Standard with Premium-add on
    168 Views, 1 Replies
    02-29-2012 07:39 AM
    Hi there,
    I would to know if there is any possibility to install Autodesk Vault Workgroup 2012 on Windows SBS 2011 (SBS 2011 Standard) with db engine SQL SBS 2011 (SBS 2011 Premium-add on) ? Do you have any experience in this matter ?
    Did you installed such products on one server (physicaly one computer/hardware) ?
    Or should I downgrade any SBS product for succesfully installation of Autodesk Vault Workgroup 2012 ?
    Please give me any advice or suggestion.
    FlisK
    Please use plain text.
    Employee
    Senthil-Autodesk
    Re: Autodesk Vault Workgroup 2012 on SBS 2011 Standard with Premium-add on
    02-29-2012 06:47 PM in reply to: flisk
    You can refer the following page for what operating systems are supported for the different releases of Vault.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15406324&linkID=9261340#section4
    Thanks!
    Senthil Kumar
    Sr QA Analyst
    Autodesk, Inc.
    Be sure to check out the Vault Help Wiki!
