• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    New Member
    Autodesk Vault Workgroup 2012 - LogIn Screen / server name
    168 Views, 1 Replies
    05-17-2012 03:09 AM
    Hi All
    On the Login window there are :
    user
    password
    server
    database
    I got problem with setting up a server name. I've tried put ACADSERVERPATH=myservername in the ini file in [Vault] part, then I've edited mst CONFIG_TRANSFORM=VaultWkg.mst and add this property, but each time the server section on the Login windows is empty.
    Please let me know how to setup server to appear for end user.
    Thx.
    Please use plain text.
    Employee
    Re: Autodesk Vault Workgroup 2012 - LogIn Screen / server name
    05-23-2012 07:51 AM in reply to: Styrop14n
    I would modify the following file:
    C:\Users\<UserName>\AppData\Roaming\Autodesk\Autodesk Vault Professional 2013\ApplicationPreferences.xml
    I am not 100% sure if that would keep the vault server present if the user never logged in.  There might be other things that are required.
    -Jim
