• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    Member
    Autodesk Vault 3 restore error
    82 Views, 0 Replies
    08-07-2009 03:55 AM
    Is there any way to import a file from vbak Autodesk Vault 3 to SQL Express 2005 ?
    Bukup made in the vault version 3 does not want to restore, because the repository has about 2 GB.
    I installed SQL Express 2005. You can attach a mdf base, but you can not use the file vbak.
    Is there some way to Autodesk Vault 3 for Inventor 8 log on to the database sql express?
    Upgrade to 3 vault sql express does not work.
    I installed SQL Express as a separate engine. Edited by: edkolas on Aug 7, 2009 10:57 AM
    Please use plain text.
