• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault
    ScottMoyse
    “An error occurred when applying configuration. See the log for detail.”
    158 Views, 2 Replies
    05-29-2012 04:09 AM
    Check out this post to help you fix up this error message:
    http://designandmotion.net/autodesk/vault-export-config-adms-error/
    Cheers
    Scott Moyse
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
    Please use plain text.
    Employee
    Re: “An error occurred when applying configuration. See the log for detail.”
    06-10-2012 08:43 PM in reply to: ScottMoyse
    Dear Scott,
    Thinks for your posting :smileyhappy:
    From log file, I notcie that the log shows there are duplicate rule name. Please check all the rules and make sure there are no duplicate rule names.
    Please let me know if the solution not works.
    Rohn
    ScottMoyse
    06-10-2012 10:14 PM in reply to: ScottMoyse
    Umm cheers for replying. I think you may have misunderstood, I stated the solution you have above in my blog post, you are correct it does work, however it is a bug which will need fixing at some point. Thanks again for taking the time to reply.
    Cheers
    Scott Moyse
