Autodesk Vault
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
ASPX file failed to run at URL...
- Highlight
- Email to a Friend
- Report Inappropriate Content
I'm trying to Install Vault 2011 on my local PC for the purposes of testing and development, but I'm having problems installing.
When I get to the pre-install checks I get the eror saying:
"ASPX file failed to run at URL: 'http://localhost/TestASP/TestASPNet.aspx"
I've also attached the complete log file for interest.
I've gone through the help on this page:
And the instructions in the help file (below):
- ASPX file failed to run at URL: "http://localhost/TestASP/TestASPNet.aspx".
The test ASPX did not run properly. Re-register the ASP.Net filters. At the command line, enter:
c:\windows\microsoft.net\framework\v2.0.50727\aspn
et_regiis -i -enable On a 64-bit operating system, enter:
c:\windows\microsoft.net\framework64\v2.0.50727\as
pnet_regiis -i -enablec:\windows\microsoft.net\framework\v2.0.50727\aspn et_regiis -i -enable Also, check to make sure that the default web site is using version 2.0 of ASP.Net. To change this setting, right-click My Computer and then select Manage. In the Computer Management window, expand Services and Applications > Internet Information Services > Web Sites and then right-click Default Web Site and select Properties. In the Default Web Site Properties dialog, click the ASP.NET tab. From the ASP.NET version drop-down list, select 2.0.
With the instructions above, I don't have an ASP.NET tab in the Web Site Properties dialog, but in the IIS Manager, the ASP.NET version is shown as V2.0.50727 (32-bit) and is set to 'allowed'.
Is there anything else I can try? I'm didn't think it'd be this hard...
FYI I'm running Windows XP SP2 on a x64 box.
Hope you can help!
Re: ASPX file failed to run at URL...
- Highlight
- Email to a Friend
Are you serving anything else up besides Vault on your IIS? I am thinking that you might have to uninstall IIS based on http://wikihelp.autodesk.com/Vault/enu/Help/Help/0
-Jim
- Highlight
- Email to a Friend
IIS isn't being used for anything at the moment, This is my local client machine, I'm installing for dev/testing only.
I've uninstalled and re-installed IIS and re-run the pre-check test, but no luck so far.
Any other suggestions?
Cheers
- Highlight
- Email to a Friend
You might want to check this other thread out:
http://forums.autodesk.com/t5/forums/replypage/boa
Unfortunately, it might be faster to get a response thru product support.
-Jim
- Highlight
- Email to a Friend
Wrong link...
- Highlight
- Email to a Friend
My bad... It should be this one: http://forums.autodesk.com/t5/Autodesk-Vault/Vault
Name of the thread is "Vault server 2012 upgrade to Vault server 2013".
-Jim
