Autodesk Vault
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ACA 2013 with Vault Pro 2013 Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure which product exactly is having tddhe problem here, and I was hoping to get some assistance. The user is getting the following error when attempting to check out drawings from Vault:
I asked him to get the details from the crash, and this is the top portion of the results:
************** Exception Text **************
System.InvalidOperationException: Invoke or BeginInvoke cannot be called on a control until the window handle has been created.
at System.Windows.Forms.Control.MarshaledInvoke(Contr
at System.Windows.Forms.Control.BeginInvoke(Delegate method, Object[] args)
at Autodesk.DataManagement.Client.Framework.Vault.For
at System.Threading.ExecutionContext.Run(ExecutionCon
at System.Threading.QueueUserWorkItemCallback.System.
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWa
Is there anyone adept at deciphering this? This issue is hitting him often, but it appears to be only the one user.
Re: ACA 2013 with Vault Pro 2013 Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The issue is coming from the Vault side of things. A support case is probably the best route to take. Based on the error I'm a bit surprised that it is only happening for one users. Does that user have different Service Packs/Hotfixes installed than others?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the reply, I'll consider going the support route when I take posession of that laptop later this week.
His patch level should be the same as most other users, I set this machine up in parallel with quite a few other identical machines, so unless he's made changes it should be a typical setup.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, sounds good. In the meantime, do you know the steps to reproduce the issue on his machine? I'll see if I can reproduce it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Has there been any progress with this? We're having this issue, and have been struggling with it.
By the way, this issue is specific to several users on our system. We don't have any steps to reproduce it however, as it seems fairly random. Sometimes we can't get past the "Open From Vault" dialog screen, and others we can open many files until we have issues. It's always to do with the "Open From Vault" dialog. I have been able to get the crash to occur by simply selecting some files too.
Richard
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Richard,
I have no update (i.e. I don't have a reproducible case). The best route for you would be to open a case with support.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can't recall exactly, but I think we solved this by finding out that the drawing itself was corrupted. Trying to open and check out simultaneously caused this error.
Instead, we did a Get, then browsed to the file's location on the hard drive and opened it directly with AutoCAD. AutoCAD failed to open the file. Vault returns odd error messages wnen you try to do the simultaneous checkout/open on a file that has problems.
Like I said, I'm not 100% sure this is the solution for this problem, but I feel like it probably was.
