• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    0 Kudos
    Update Autoloader to allow easier batch upload
    Status: Comments Requested
    by Valued Contributor m_simons on ‎11-27-2012 12:40 PM
    I would like to see an easier way to batch upload design files, particularly older autoCAD .dwg files.
    For instance if my company is re-using a design and we have over 3000 CAD files from...let's say 1995, I want to be able to put every single one of these files into Vault for modification, reference, and use in new CAD files.
    Right now the only straight forward way to do this is to use Autoloader, and lets be honest Autodesk, Autoloader is a dumpster fire. It is extremely finicky with directory structure, file associations, file types, and file age. So my CAD files circa 1995 give Autoloader a headache and it refuses to load the files into Vault with any amount of coercion. I understand the premise of Autoloader and maintaining file association but I would still rather get a root canal than use Autoloader because it is impossibly stubborn.
    So what about drag and drop? I would like to drag and drop these files using Vault Explorer, I have administrator rights to the vault, so one would think I would understand the CAD system well enough and could make the decision whether or not to ignore file associations right? No way no how. This is a design file and must be checked in using the appropriate application. Hey Autodesk, how about you allow administrators to check in design files regardless of file associations?
    So how did I get my 3000 cad files from 1995 into Vault? I could have spent 3 months of my company's time opening up every drawing, converting to a modern CAD file, and check them in one by one. No way, isn't this a major feature of Vault, to save time? And after all, time is money, so I created an ACADE project, added the 3000 cad files to the project, and then checked the project in, ACADE kicking and screaming the whole time. This took 10 times longer than it should have and involved many additional steps.
    So Autodesk, I'm begging that you allow easier methods to bulk upload design files. Your users will find a way to get around Autoloader and put the files in anyway, why not just fix Autoloader so it does what your loyal CAD users want? I don't care if the CAD file is too old for Autoloader to open and check for file associations, put the stupid thing in Vault! Also, Autoloader is so locked down anyway why is a user required to have administrative rights to use it?
    Vault Explorer allows you to add CAD files by turning off the restriction. Also you can use the Add Folder option in AutoCAD to add the 3000 files using the CAD product. You can also create a LISP script to perform an update and add the file to Vault. Have you tried any of these?
    Comments
    by Board Manager ihayesjr on ‎01-14-2013 07:10 AM
    Status changed to: Comments Requested
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    Top Kudoed Authors
