Server Side Events/ Extensions
I'd like to have the ability to write Server Side Extensions which can be executed when an Webservice Command Event is fired.
That would make it possible to keep data consistent more easily (currently, if a client doesn't have the necessary Extension installed, the event is not handled).
I know, you can create a Job to be executed on the JobProcessor to circumvent that problem, but Jobs are delayed and events would be more immediate.
An alternative solution could be some Server Based extension deployment. If extensions could be stored on the server and each client executed/loaded these, the problem might be solved too.
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
