Description
When Families are added to Vault, none of the Family parameter data (inside the file) is accessible for searching against.
Impact
This metadata has to be manually added to the files via the properties, which is a very time consuming process.
Severity
High
Solution
Vault requires a means to expose the data from the Family’s Type Parameters (inside the file) or associated Type Catalog file so that files can be efficiently searched.
As an idea only, this could potentially be achieved through the addition of a new tab (Types) which for each Family will display this data.
This ideally needs to be separated from the meta-data which we can additionally add to files using the Vault properties.
