- Mark as Read
- Email to a Friend
- Printer Friendly Page
I would like to have the ability to set up a pre selected list of properties to edit for a specific object type in Vault Pro. For example, if I select a File and choose Edit Properties, the edit window would open with a specific list of editable properties. If I select, however, a Custom Object and choose Edit Properties the edit window would open with a different list of editable properties for that object type. Right now, the only way to do this is with the properties grid. I have to search through a massive list of system and user properties, highlight the ones I want and choose Edit Selected Properties. I have to do this for each individual object that I want to edit.
- Mark as Read
- Highlight
- Email to a Friend
You can edit mulitple properties on mulitple documents in one step. Select all of the documents, then pre-select the properties..... then select 'Edit Selected Properties'.
- Mark as Read
- Highlight
- Email to a Friend
There are some apps that you should take a look at.
DECO lets you create your own edit window for Custom Object properties.
http://justonesandzeros.typepad.com/blog/2012/07/d
Reitec.Vault.Datasheet lets you create your own edit window for file properties.
- Mark as Read
- Highlight
- Email to a Friend
This should be default functionality. Along with multi-select lists for properties and linked lists between fields.
Basically, let someone create a property entry form.
- Mark as Read
- Highlight
- Email to a Friend
