• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    3 Kudos
    cbenner
    Edit Properties Flexibility.
    Status: Future Consideration
    by *Expert Elite* on ‎12-12-2012 07:26 AM
    I would like to have the ability to set up a pre selected list of properties to edit for a specific object type in Vault Pro.  For example, if I select a File and choose Edit Properties, the edit window would open with a specific list of editable properties. If I select, however, a Custom Object and choose Edit Properties the edit window would open with a different list of editable properties for that object type.  Right now, the only way to do this is with the properties grid.  I have to search through a massive list of system and user properties, highlight the ones I want and choose Edit Selected Properties.  I have to do this for each individual object that I want to edit.
    Comments
    by Valued Mentor on ‎12-12-2012 07:28 AM
    You can edit mulitple properties on mulitple documents in one step.  Select all of the documents, then pre-select the properties.....  then select 'Edit Selected Properties'.
    by Employee Redmond.D on ‎12-20-2012 04:56 AM
    There are some apps that you should take a look at.
    DECO lets you create your own edit window for Custom Object properties.
    http://justonesandzeros.typepad.com/blog/2012/07/deco-custom-ui-without-custom-code.html
    Reitec.Vault.Datasheet lets you create your own edit window for file properties.
    http://apps.exchange.autodesk.com/VLTC/Detail/Index?id=appstore.exchange.autodesk.com%3areitecvaultd...
    by tmoney2007 on ‎02-07-2013 08:12 PM
    This should be default functionality.  Along with multi-select lists for properties and linked lists between fields.
    Basically, let someone create a property entry form.
    by Board Manager ihayesjr on ‎02-11-2013 11:25 AM
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    Top Kudoed Authors
