• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    56 Kudos
    Don't asking to check-out a file if I'm not allowed to do that
    Status: Under Review
    by Distinguished Contributor xdumont on ‎06-22-2012 05:04 AM
    Vault must check if the file is locked or not before asking to check out.
    If the file is locked => don't ask, just open-it read only.
    If the file is not locked => ask if you want to check out.
    Thanks in advance.
    Comments
    by *Expert Elite* on ‎08-31-2012 05:38 AM
    Not sure if this is a Vault thing or the application that is used to open the file.  I know if a .dwg is opened from Vault Explorer that is not checked out, once Autocad gets control, it will prompt "xyz.dwg is currently in use or is read-only. Would you like to open the file read-only?". Only way to avoid this is to check-out the file in VE before its opened.
    by Board Manager ihayesjr on ‎09-20-2012 09:51 AM
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    Top Kudoed Authors
