• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    4 Kudos
    obourne
    Digital Signatures Directly in Vault
    Status: Comments Requested
    by Valued Contributor obourne on ‎08-20-2012 10:52 AM
    There should be a way to create digital signatures from within Vault that would write directly to the drawing files. Currently if I want a "legal" signature I need to print a hard copy to sign which then becomes the legal copy on file (not the DWG) or I need to publish a PDF and use Verisign which then means the PDF becaomes the legal copy.
    It makes sense to me to have all this done directly from Vault (ideally PLM 360 as well).
    This is a very important point for regulated industries i.e. FAA, FDA etc.
    Hi obourne, is the DWG made from Inventor or AutoCAD?
    Comments
    by Board Manager ihayesjr on ‎08-20-2012 03:23 PM
    Status changed to: Comments Requested
    by Valued Contributor obourne on ‎08-20-2012 03:29 PM
    IV.
    by Valued Contributor DannyVanDuijn ‎01-26-2013 07:53 AM - edited ‎01-26-2013 07:54 AM
    A verificated Sign-off method would be very appreciated. When a file/item gets released by an user then the system must verify the user again by showing an extra sign off dialog where the user has to fill in its user credentials.
    The workflow would be:
    Login Vault > use credentials
    Releasing a file / item > use credentials again.
    Then the job processor generates the visualization file automatically (in pdf format).
    Of course should this be a option which is controlled by the admin.
    Danny van Duijn
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    Top Kudoed Authors
