- Mark as Read
- Email to a Friend
- Printer Friendly Page
Copy Design with rename-opt ions like replace and delete
Status:
Accepted
to copy a design needs often a lot of time to rename.
If the copy should bei in the same folder, you have to delete at every file the " (2)" and rename it.
There are the options prefix and suffix but i think its not enough.With them you can olny add something, not replace ore delete.
With options like rename it will be quicker.
Example:
You have files with speeking filenames like this:
0100.025.001
0100.025.002
0100.025.003
0100.025.004
and want to make this:
0100.026.001
0100.026.002
0100.026.003
0100.026.004
you have need a lot of time.
Best regards
Michael
- Mark as Read
- Highlight
- Email to a Friend
I forget something:
with PTC Intralink / Windchill you can make this example easy with:
Replace ".025" with ".026"
I think thats something for Vault, too.
- Mark as Read
- Highlight
- Email to a Friend
You CAN do a replace function in Copy Design, at least as of Vault 2011.
In the file name or loction column, right click and choose replace. It takes some time, but is still a lot quicker than changing each one individually.
I try to set up my file name structure such that there is a common field in all of my file names, which is easy to replace in copy design... for example I prefix everything with the project number.
- Mark as Read
- Highlight
- Email to a Friend
cbenner is correct. you have to make sure you right click on the cell and not on the column header, which is counter intuitive. But its definitely there.
- Mark as Read
- Highlight
- Email to a Friend
I found it, too. It works. Thanks to cbrenner.
From my side, this thread can be deleted.
But with this hits, i seems, that others had missed this function, too.
It seems that this function is to hidden. I think the place at the front like prefix and suffix is the better one.
- Mark as Read
- Highlight
- Email to a Friend
Hi all
Took me a while to find it too... there is a bit of a trick to the right-clicking
The renaming could definetly use more options
If they need ideas, it could have similar options to the freeware program 'Bulk Rename Utility'
I find that the 'Replace All' rarely works, and that I have to click 'Replace' for every instance... anyone else have this bug?
I am running Collaboration 2011
- Mark as Read
- Highlight
- Email to a Friend
I have exactly the same situation. 99% of the time I have to select every instance. And like others mentionded before, a well hidden feature. I never knew it. It will save us a lot of work. (esp. copy design of tube&Pipe, frame generator and stress files)
- Mark as Read
- Highlight
- Email to a Friend
There is a replace funktion in the "Copy Design dialog" ..
- Mark as Read
- Highlight
- Email to a Friend
