• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    1 Kudo
    brendan.henderson
    Copy Design from Library to Projects
    Status: Under Review
    by Distinguished Contributor brendan.henderson on ‎06-25-2012 03:18 PM
    I often want to do this but can't. I have to copy design to a Library folder and then manually move the files to a Projects folder.
    Comments
    by Board Manager ihayesjr on ‎07-05-2012 11:41 AM
    Status changed to: Comments Requested
    Brendan, thanks for posting this idea. Can you express why the original files are in a Library folder instead of in a non-Library folder?
    by Distinguished Contributor brendan.henderson on ‎07-08-2012 02:53 PM
    Our VAR setup Vault Basic with Library.ipj and Projects.ipj which we are happy with. All files in Library are made and locked away (or I wish they were but that is another topic). But we are constantly adding items to the Library either as new or as copy design.
    by Valued Contributor gradcliffe on ‎07-23-2012 01:40 PM
    We have a similar need because we have template assemblies for tooling design on different pieces of manufacturing equipment.  Many of the base machine's components are Library-type parts that will never (or rarely) change, but the final assemblies always contain some customized interchangeable parts like die sets, punches, form tools, grippers, cams, linear slides, levers, etc. that are essentially similar but never exactly alike.  A convenient solution is to have complete assemblies of various machines+tooling, with the interchangeable components in place, ready to customize, and use Copy Design on that for each job.
    My workaround has always been to keep these template assemblies in regular (non-library) folders, but that can cause frustrating problems with "library" components getting checked out unnecessarily or having lifecycle changes applied when they really shouldn't be.
    by Employee mikel.martin on ‎04-12-2013 06:38 AM
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    Top Kudoed Authors
