• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    22 Kudos
    Autodesk Vault 'Clone Structure' Add-in - Make as permanent feature
    Status: Under Review
    by Distinguished Contributor Brausmith on ‎07-01-2012 10:02 PM
    Description
    Starting a folder structure for a new project in Vault can be a timely process. From reproducing the folder structure, and in particular having to manually assign permissions to the newly created project structure.
    Impact
    Not having this feature has a significant impact on the process for starting a new project, particularly one which has a somewhat complex folder structure.
    Due to this product limitation, it might actually put users/clients off from using Vault in the first place if there is such a time consuming project startup administration process.
    Severity
    Medium-High
    Solution
    Roll the Autodesk Vault 'Clone Structure' Add-in from Autodesk Consulting in as a permanent feature in Vault to aid in speeding up the project startup process.
    http://underthehood-autodesk.typepad.com/blog/2011/09/meet-the-new-project-same-as-the-old-project.h...
    Comments
    by Board Manager ihayesjr on ‎09-28-2012 06:47 AM
    IdeaStation Guidelines
    Review guidelines and best practices
    before posting a new idea
    Top Kudoed Authors
