Advance search of numeric value Property
Currently vault does not support wildcards when searching numeric values. In order to search a range, you must set up multiple conditions of >= or <=.
Please incorporate wildcards for Numeric property searches. For example
Outside Diameter between 100 an 200 could be 100 - 200
Or even set an additional operator in list of "above, below, >, < etc" that says "Range" or "Between" then allow for multiple values to be entered.
Jeremy
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
