• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Active Member
    calling a drawing from the vault within VB.NET
    165 Views, 3 Replies
    09-28-2012 01:20 PM
    What is the vault name or procedure for getting an autoCAD drawing from the vault
    example from the c drive I use:
    g_acadDoc = m_AcadApp.Documents.Open("C:\VAULT_WIP\DWG\L324532.dwg")
    What would you use instead of C:\
    Please use plain text.
    Employee
    Re: calling a drawing from the vault within VB.NET
    10-01-2012 05:51 AM in reply to: dbvetter01
    You call DownloadFile, which gives you a byte array.  You can then save the array to any location on disk that you want.  See the VaultFileBrowser sample in the SDK for an example of a download.
    Doug Redmond
    Software Engineer
    Autodesk, Inc.
    http://justonesandzeros.typepad.com/
    Active Member
    10-01-2012 01:26 PM in reply to: dbvetter01
    Isn't there a way to map the database as a drive letter?  or server path?  It would be so much easier for programmers.
    In other EMDS you can map the main vault as a drive letter i.e V:\
    Employee
    10-03-2012 04:52 AM in reply to: dbvetter01
    Autodesk.Connectivity.Explorer.ExtensibilityTools.dll has some utilities to help with this.
    There is a DownloadFile function which will download to the user's working folder location.
    Doug Redmond
    Software Engineer
    Autodesk, Inc.
