Vault API sample code problem
- Mute
- Permalink
- Report
Something strange happened yesterday and I can't find the solution - I was using the Item Editor sample code and everything worked fine at first. For no apparent reason it stopped working, when I try to create an item it gives a "Promote Error". When I debug I get an error at the promote files line saying "there is no source code at the current location" and then the promote error followed by error code 155.
I did not modify the sample code in any way, and I have re-installed the SDK to make sure it was clean. I also applied the API patch. I am assuming that it is a VS / config issue and I have googled it but with no success. My setup is Vault Pro 2012 running on Win 7 64bit (server & client running on dev machine) / VS 2008 Pro. Can anyone help please?
