Autodesk Vault Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Thumbnail Property
- Highlight
- Email to a Friend
I'm using the example from the API help to create a image from the thumbnail property data. But I always get a GDI+ exception when creating the Metafile from the stream.
Dim thumbnailRaw As Byte() = CType(propInst.Val, Byte())
Dim stream As System.IO.Stream = New System.IO.MemoryStream(thumbnailRaw, 12, thumbnailRaw.Length - 12)
Dim metafile As System.Drawing.Imaging.Metafile = New System.Drawing.Imaging.Metafile(stream)
Dim retVal As Image = metafile.GetThumbnailImage(width, height, New Image.GetThumbnailImageAbort(AddressOf GetThumbnailImageAbort), IntPtr.Zero)
tream.Close()
Regards, Stephan
Re: Thumbnail Property
- Highlight
- Email to a Friend
Hello Stephan,
It looks like the code you're using if from Doug's older post about reading thumbnails. If you're using this code on Vault 2012 and newer, it has the possibility of throwing the GDI+ exception if the image format of the thumbnail is not a metafile. This can happen because new image formats were added for thumbnails in Vault 2012. Please see this post on Doug's blog: http://justonesandzeros.typepad.com/blog/2011/05/v
Daniel Dulzo
Software Engineer
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Daniel,
thanks, now it works.
I used the code from the API help (Vault 2013)! Please review the docs, it is the second time in the last weeks that I found incorrect information in the Knowledge Base Articles:
-Viewing Thumbnail Properties
-Uploading and Downloading (XML is for server side configuration not client side)
Regards, Stephan
