• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Vault Customization
    Active Contributor
    Thumbnail Property
    151 Views, 2 Replies
    04-30-2012 03:53 AM
    I'm using the example from the API help to create a image from the thumbnail property data. But I always get a GDI+ exception when creating the Metafile from the stream.
    Dim thumbnailRaw As Byte() = CType(propInst.Val, Byte())
    Dim stream As System.IO.Stream = New System.IO.MemoryStream(thumbnailRaw, 12, thumbnailRaw.Length - 12)
    Dim metafile As System.Drawing.Imaging.Metafile = New System.Drawing.Imaging.Metafile(stream)
    Dim retVal As Image = metafile.GetThumbnailImage(width, height, New Image.GetThumbnailImageAbort(AddressOf GetThumbnailImageAbort), IntPtr.Zero)
     tream.Close()
    Regards, Stephan
    Please use plain text.
    Employee
    Daniel.Dulzo
    Re: Thumbnail Property
    04-30-2012 07:54 AM in reply to: wannensn
    Hello Stephan,
    It looks like the code you're using if from Doug's older post about reading thumbnails. If you're using this code on Vault 2012 and newer, it has the possibility of throwing the GDI+ exception if the image format of the thumbnail is not a metafile. This can happen because new image formats were added for thumbnails in Vault 2012. Please see this post on Doug's blog: http://justonesandzeros.typepad.com/blog/2011/05/viewing-thumbnails.html. Please try the code sample there and let me know if that works.
    Daniel Dulzo
    Software Engineer
    Active Contributor
    05-01-2012 11:59 PM in reply to: Daniel.Dulzo
    Hi Daniel,
    thanks, now it works.
    I used the code from the API help (Vault 2013)! Please review the docs, it is the second time in the last weeks that I found incorrect information in the Knowledge Base Articles:
    -Viewing Thumbnail Properties
    -Uploading and Downloading (XML is for server side configuration not client side)
    Regards, Stephan
