• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Searching for Files by Criteria - VB .Net using API
    829 Views, 11 Replies
    03-19-2012 04:37 AM
    I need to run the search criteria and get the results using VB code.
    Here is the search criteria
    File Name Contains SrchFile and
    Latest Released Revision Is True
    If there is a example of VB /c# code to do this?
    Your help is appreciated.
    Please use plain text.
    Employee
    Daniel.Dulzo
    Re: Searching for Files by Criteria - VB .Net using API
    03-19-2012 07:37 AM in reply to: shashipatra
    Dear shashipatra,
    The Vault SDK comes packaged with some example projects in both VB and C Sharp. Specifically, the Vault File Browser example has a form that performs a search in Vault using various search conditions. I would suggest you look thought this code to see how to search for files in Vault.
    Daniel Dulzo
    Daniel Dulzo
    Software Engineer
    03-19-2012 11:03 AM in reply to: Daniel.Dulzo
    I was able to come up with following code :
    How do i add one more condition for
    I know the PropID for Latest Released Revision Property is 22 but whats the condition code for 'Is True' ?
    Dim SrcCond AsNew SrchCond
    ' search for files
    Dim fileList As List(Of File) = New List(Of File)()
    Dim bookmark AsString = String.Empty
    Dim status As SrchStatus = Nothing
    With SrcCond
                .PropDefId = 8
                .SrchOper = 1
                .PropTyp = PropertySearchType.SingleProperty
                .SrchTxt = "488278"
    EndWith
    'Create a search condition array
    Dim SrcConds(0) As SrchCond
            SrcConds(0) = SrcCond
    While (status IsNothingOrElse fileList.Count < status.TotalHits)
    Dim files As File() = m_serviceManager.DocumentService.FindFilesBySearchConditions( _
                    SrcConds,
    Nothing, Nothing, True, True, bookmark, status)
    If (Not files IsNothing) Then
                    fileList.AddRange(files)
    EndIf
    EndWhile
    If (fileList.Count > 0) Then
    'iterate through found files and display them in the search results list box
    ForEach file As File In fileList
    'create the list item that will wrap the File
    Dim fileItem As ListBoxFileItem = New ListBoxFileItem(file)
                    m_searchResultsListBox.Items.Add(fileItem)
    Next file
    Else
    EndIf
    Employee
    Daniel.Dulzo
    03-19-2012 12:09 PM in reply to: shashipatra
    There isn't a search operation for "is true." Instead, you use the operation "is exactly (or equals)" and set the search text to "True" or "False" (it is probably best to use Boolean.TrueString or Boolean.FalseString). For example:
    Dim searchCondition As SrchCond = NewSrchCond()
    searchCondition.PropDefId = 22 'haven't confirmed this is the right propdef id
    searchCondition.PropTyp = PropertySearchType.SingleProperty
    searchCondition.SrchOper = 3
    searchCondition.SrchRule = SearchRuleType.Must
    searchCondition.SrchTxt = Boolean.TrueString
    You can find more information about different search operation codes and which property data types they are valid for by looking at the SDK's documentation for the SrchCond.SrchOper field. The documentation can be found under the docs directory in the install directory of the Vault SDK itself.
    Daniel Dulzo
    Daniel Dulzo
    Software Engineer
    03-19-2012 12:15 PM in reply to: Daniel.Dulzo
    I added the codes but results in showing everything from Vault :
    My condition is File Name contains "488278" and Latest Released Revision is True :
    ' search for files
    With SrcCond
                .PropDefId = 8
                .SrchOper = 1
                .SrchTxt = "488278"
    EndWith
    With SrcCond
                .PropDefId = 22
                .SrchOper = 3
    EndWith
            Array.Resize(SrcConds, SrcConds.Length + 1)
            SrcConds(SrcConds.Length - 1) = SrcCond
                   SrcConds,
    EndIf
    EndWhile
    Next file
    Else
    EndIf
    Employee
    Daniel.Dulzo
    03-19-2012 12:38 PM in reply to: shashipatra
    It looks as though your code below might have a programming error. It appears you're accidentally using the same SrchCond object for both search conditions in your array. I would assume your search is then returning of the latest revisions of all files in your Vault. Try initializing your search condition array differently. One possible solution might be as follows:
    Dim SrcCond As New SrchCond
    With SrcCond
       .PropDefId = 8
       .SrchOper = 1
       .SrchTxt = "488278"
    End With
    Dim SrcCond2 As New SrchCond
    With SrcCond2
        .PropDefId = 22
        .SrchOper = 3
     End With
    Dim SrcConds(1) As SrchCond
    SrcConds(1) = SrcCond2
    Hopefully after this change, your search will behave as expected.
    Daniel Dulzo
    Daniel Dulzo
    Software Engineer
    03-20-2012 06:50 AM in reply to: Daniel.Dulzo
    Thanks . That works great. Now i get the correct file names.
    Is there a way to launch the latest released revision on the Vault web client like below?
    The link has a IterationID passed to the FilePreciewPage.aspx. How i can get IterationID using the fileName.
    http://VaultServer/AutodeskDM/webclient/FilePreviewPage.aspx?iterationId=778902
    Employee
    Daniel.Dulzo
    03-20-2012 07:39 AM in reply to: shashipatra
    I'd like to make a quick correction about the SrchTxt field when searching on boolean properties. Due to possible localization issues, it's actually best to use "0" and "1" as false and true values because the text strings used for these values will, of course, differ based on language. By sticking with "0" and "1", you can avoid issues that might occur if your client and server are in different languages.
    To answer your question about creating hyperlinks for the web clients, I'd like to direct you to the Vault Customization blog, Just Ones and Zeros, maintained by Doug Redmond. He has a utility for creating links that sounds pretty similar to what you're trying to do here: http://justonesandzeros.typepad.com/blog/2011/06/hyperlink-maestro.html. Playing with the utility and looking through the source code will hopefully give you some insight into what you're trying to do. It's probably worth noting that links with a specific file itration ID can get stale quickly because they will always open to the same file version. You might want to keep this in mind, depending on how you're going to be using these links.
    The iteration ID is the Id field on the Autodesk.Connectivity.WebService.File class. I've also answered this question on the other thread you've created so that future user will be able to locate the answer more easily.
    Daniel Dulzo
    Software Engineer
    03-20-2012 09:49 AM in reply to: Daniel.Dulzo
    I noticed that i get different results when using the Web Client Search and Windows API Search.
    My Web Client Search Condition is
    File Name Contains 488278
    Latest Released Version is True
    My API code which i have posted above using the same condition but why i am getting different results.
    When i say different results , number of resulting files are different and file.id (Iteration ID) are different.
    I did chaneg boolean.Tostring to '1' but still i am getting different results.
    HELP!!!
    Employee
    Daniel.Dulzo
    03-21-2012 08:02 AM in reply to: shashipatra
    The results might differ because your code above seems to be setting the latestOnly parameter of the  FindFilesBySearchConditions() method to true. If your search using the web client is including all versions of files, this would likely cause the number of files found to differ between the two searches. I would suggest looking at the SDK documentation for the FindFilesBySearchConditions() method, as more information can be found there.
    Daniel Dulzo
    Software Engineer
