Run Vault explorer command from API
I have a question. Is possibility run standard Vault explorer command from API. I have created command to write properties fields in custom Tab. Code working ok, but the properties are mapped and after update I need synchronize with document (docx). It can be done by Actions-> Synchronize Properties. Is possible just run this command for my file from API ?
Darius
Redmond.D
Sorry, no.  You can't launch a Vault Explorer command through the API.
Doug Redmond
Software Engineer
Autodesk, Inc.
I need synchronize properties from Vault to *.docx custom properties. How it should be done?
Redmond.D
IExplorerUtil.UpdateFileProperties() is what you want to use.  It updates a property in Vault and in the file.  The utility can be found in Autodesk.Connectivity.Explorer.ExtensibilityTools.dll which is a bit tricky to work with.
Doug Redmond
Software Engineer
Autodesk, Inc.
