• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Vault Customization
    Active Contributor kbo
    Active Contributor
    kbo
    Accepted Solution
    Refresh Vault Pro Explorer
    136 Views, 4 Replies
    01-18-2012 05:15 AM
    I create some folders i the Vault explorer with code below. My problem is when the folders are createt i have to press the refresh button to get the folders to show up.
    can anybody provide a code example on how to trigger the refresh of the Vault Client explorer?
    regards.
    Kent boettger
      Private Sub KBCommandHandler()
            'MsgBox("Trykkede KBCommand")
            Dim MyFolderParent As Folder = mDocSvc.GetFolderByPath("$/MonsunVaultFiler/Ordre")
            Dim MyFolderName As String
            MyFolderName = "PROJEKT-ABC"
            Dim MyFullFolderName As String
            MyFullFolderName = (MyFolderParent.FullName & "/" & MyFolderName)
            Try
                'Check if the folder exist
                Dim MyFolderId As Long = mDocSvc.GetFolderByPath(MyFullFolderName).Id
                If MyFolderId.ToString > 0 Then
                    'MsgBox("Projekt folder findes allerede")
                    MsgBox("Folder already exist")
                    Exit Try
                End If
            Catch ex As Exception
                'MessageBox.Show(ex.ToString(), "Projektfolder findes ikke")
                Dim MyNewFolder As Folder = mDocSvc.AddFolder(MyFolderName, MyFolderParent.Id, False)
                Dim MyNewSubFolder0 As Folder = mDocSvc.AddFolder("00-Konfigurator", MyNewFolder.Id, False)
                  MsgBox("Folder was created")
            End Try
        End Sub
    m.becher
    Re: Refresh Vault Pro Explorer
    01-18-2012 05:44 AM in reply to: kbo
    If your code running as a Vault Client Extension and you Implement the IExtension Interface you can set the Property
    ForceRefresh = true from the Context-Object. The Context Object are stored in the
    CommandItemEventArgs in the Execute-Event from the CommandItem Object...
    Hope this help
    Michael
    Active Contributor
    kbo
    01-18-2012 06:28 AM in reply to: m.becher
    Yes it is running as a vault client extension, I can't figure out how to implement this as you descripe it please help.
    here is me command item how do i put in this force refresh option?
    regards.
    Kent boettger
    Dim
    KBCmdItem AsNewCommandItem("KBCommand", "KB Command")
    AddHandler KBCmdItem.Execute, AddressOf KBCommandHandler
    m.becher
    01-18-2012 07:40 AM in reply to: kbo
    You must change the Method signatur 'KBCommandHandler' to
      Private Sub KBCommandHandler(ByVal s As ObjectByVal e As CommandItemEventArgs)
    the you can access over e.Context the Property. Look at the SDK 'Hello World' sample. Note this code is for Vault 2012 i can't say if it has change in recent API versions.
    Active Contributor
    kbo
    01-20-2012 01:09 AM in reply to: m.becher
    Thanks for Your help :smileyhappy: ended up with this and now it works.
     e.Context.ForceRefresh = True
