Autodesk Vault Customization
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Refresh Vault Pro Explorer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I create some folders i the Vault explorer with code below. My problem is when the folders are createt i have to press the refresh button to get the folders to show up.
can anybody provide a code example on how to trigger the refresh of the Vault Client explorer?
regards.
Kent boettger
Private Sub KBCommandHandler()
'MsgBox("Trykkede KBCommand")
Dim MyFolderParent As Folder = mDocSvc.GetFolderByPath("$/MonsunVaultFiler/Ordre" )
Dim MyFolderName As String
MyFolderName = "PROJEKT-ABC"
Dim MyFullFolderName As String
MyFullFolderName = (MyFolderParent.FullName & "/" & MyFolderName)
Try
'Check if the folder exist
Dim MyFolderId As Long = mDocSvc.GetFolderByPath(MyFullFolderName).Id
If MyFolderId.ToString > 0 Then
'MsgBox("Projekt folder findes allerede")
MsgBox("Folder already exist")
Exit Try
End If
Catch ex As Exception
'MessageBox.Show(ex.ToString(), "Projektfolder findes ikke")
Dim MyNewFolder As Folder = mDocSvc.AddFolder(MyFolderName, MyFolderParent.Id, False)
Dim MyNewSubFolder0 As Folder = mDocSvc.AddFolder("00-Konfigurator", MyNewFolder.Id, False)
MsgBox("Folder was created")
End Try
End Sub
Re: Refresh Vault Pro Explorer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If your code running as a Vault Client Extension and you Implement the IExtension Interface you can set the Property
ForceRefresh = true from the Context-Object. The Context Object are stored in the
CommandItemEventArgs in the Execute-Event from the CommandItem Object...
Hope this help
Michael
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes it is running as a vault client extension, I can't figure out how to implement this as you descripe it please help.
here is me command item how do i put in this force refresh option?
regards.
Kent boettger
Dim
KBCmdItem AsNewCommandItem("KBCommand", "KB Command")
AddHandler KBCmdItem.Execute, AddressOf KBCommandHandler
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You must change the Method signatur 'KBCommandHandler' to
Private Sub KBCommandHandler(ByVal s As Object, ByVal e As CommandItemEventArgs)
the you can access over e.Context the Property. Look at the SDK 'Hello World' sample. Note this code is for Vault 2012 i can't say if it has change in recent API versions.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for Your help
ended up with this and now it works.
e.Context.ForceRefresh = True
